Zum Hauptinhalt wechseln
Gateway MD2614u Wireless Card Replacement
Was du brauchst
  1. Gateway MD2614u Wireless Card Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Wireless Card Replacement: Schritt 2, Bild 1 von 1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Wireless Card Replacement: Schritt 3, Bild 1 von 1
    • Lift off the cover.
  4. Gateway MD2614u Wireless Card Replacement, Wireless Card: Schritt 4, Bild 1 von 1
    • The wireless card is located to the right of the hard drive and below the RAM.
  5. Gateway MD2614u Wireless Card Replacement: Schritt 5, Bild 1 von 1
    • There are black and grey wires with gold heads attached to the top of the wireless card.
    • To remove these wires, turn the gold heads counterclockwise and pull up.
    • You will hear a snap when the heads come off.
    • It does not matter which wire you remove first, but do so one at a time.
  6. Gateway MD2614u Wireless Card Replacement: Schritt 6, Bild 1 von 1
    • Remove the two screws next to the wires with a Phillips #00 screwdriver.
  7. Gateway MD2614u Wireless Card Replacement: Schritt 7, Bild 1 von 1
    • The card will pop up 20 degrees and is loose enough to remove with your hand.
    • Carefully pull the card out to the left horizontally.
Abschluss
Toni Pipes
333 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 21-31, Regan Fall 2010 Mitglied von Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 30
Insgesamt: 4,252
