Zum Hauptinhalt wechseln
Toilet Seat Replacement
Was du brauchst
  1. Toilet Seat Replacement, Toilet Seat: Schritt 1, Bild 1 von 1
    • Measure the size of your toilet bowl to know what size seat to purchase.
  2. Toilet Seat Replacement: Schritt 2, Bild 1 von 2 Toilet Seat Replacement: Schritt 2, Bild 2 von 2
    • Twist the tops of the hinges of the currently installed toilet seat and pull toilet seat off to expose the screws.
  3. Toilet Seat Replacement: Schritt 3, Bild 1 von 3 Toilet Seat Replacement: Schritt 3, Bild 2 von 3 Toilet Seat Replacement: Schritt 3, Bild 3 von 3
    • Unscrew the screws to detach the seat.
    • If the screw is not loosening but is spinning as if it were, then hold the back plastic nut so that it can unscrew from the nut.
    • Clean the newly exposed area. This opportunity will not present itself again anytime soon so take advantage of it.
  4. Toilet Seat Replacement: Schritt 4, Bild 1 von 2 Toilet Seat Replacement: Schritt 4, Bild 2 von 2
    • Insert new special 20mm screws that are provided with the purchase of the toilet seat in the holes and tighten them.
  5. Toilet Seat Replacement: Schritt 5, Bild 1 von 1
    • Then re install the toilet seat by fitting the heads of the screws in the holes on the hinges of the seat.
  6. Toilet Seat Replacement: Schritt 6, Bild 1 von 1
    • Close caps by twisting them in the opposite direction that you did to take off the seat.
Abschluss
To re-install your previous seat, follow these instructions in reverse order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 24-5, Green Winter 2015 Mitglied von Cal Poly, Team 24-5, Green Winter 2015
CPSU-GREEN-W15S24G5
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 1,905
