Einleitung
Use this guide to remove and install the front case.
Was du brauchst
Position the camera with the bottom facing up.
Slide the battery cover in the direction of the arrow with your finger gently.
Remove the batteries
Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
2 on the left
2 on the right
3 on the bottom
Keep the battery door open
Firmly grasp the front casing and pull away from the camera.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
