Einleitung
This is the circuit board that the AV chord attaches to for transferring images.
Was du brauchst
Remove 4 screws from the right side of the camera.
There are two 3.4mm screws at the top.
There are two 2.2mm screws at the bottom.
Remove 5 screws from the base of the camera.
There are two 2.2mm screws next to the battery compartment.
There are three 4mm screws around the tripod mount.
Detach both ribbon cables using a spudger.
Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
Carefully remove the function switch cover. This unit snaps on and off.
Carefully unsnap the front logic board from the rear logic board using a spudger.
Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger.
This leaves you with the logic board and the top connection panel separate and free from the camera
Use a spudger to detach the ribbon cable from the circuit board. Lift the black clip up to unlock it as before.
Remove the 3 screws holding the lens assembly in place.
The two screws on the left are 4.5mm with washers.
The single screw on the right is 4mm.
Push the lens assembly slightly toward the circuit board, and pull the left side out of the casing first. You will have to wiggle this out gently.
Remove the entire assembly out of the casing.
The ribbons on the left and bottom of the assembly simply rest on the camera housing.
Use the spudger to unclip the top ribbon cable from the circuit board.
Gently slide the circuit board out away from the port connections. Pull it toward where the lens used to be. Some wiggling may be necessary to remove.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
