Zum Hauptinhalt wechseln
Patching a Bicycle Tire Inner Tube
Was du brauchst
  1. Patching a Bicycle Tire Inner Tube, Rear Wheel: Schritt 1, Bild 1 von 2 Patching a Bicycle Tire Inner Tube, Rear Wheel: Schritt 1, Bild 2 von 2
    • Flip the quick release lever on the wheel.
  2. Patching a Bicycle Tire Inner Tube: Schritt 2, Bild 1 von 1
    • Squeeze the brake arms together and lift the brake cable from the caliper arms.
  3. Patching a Bicycle Tire Inner Tube: Schritt 3, Bild 1 von 1
    • Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
  4. Patching a Bicycle Tire Inner Tube, Inner Tube: Schritt 4, Bild 1 von 1
    • Press the valve core while applying pressure to the tire to deflate the tire.
  5. Patching a Bicycle Tire Inner Tube: Schritt 5, Bild 1 von 2 Patching a Bicycle Tire Inner Tube: Schritt 5, Bild 2 von 2
    • Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel.
    • Slide the lever around the circumference of the wheel to completely remove the tire.
    • Alternatively, if you have multiple tire levers, see if you can clip the first lever to a spoke to keep it in place. Then insert the second lever a few inches away. Clip it to a spoke. Insert the third lever a few more inches along. Take out the second lever and insert it it a few inches past the third. Work along the rim until the tire pops off.
  6. Patching a Bicycle Tire Inner Tube: Schritt 6, Bild 1 von 1
    • Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
  7. Patching a Bicycle Tire Inner Tube, Patching a Bicycle Tire Inner Tube: Schritt 7, Bild 1 von 1
  8. Patching a Bicycle Tire Inner Tube: Schritt 8, Bild 1 von 2 Patching a Bicycle Tire Inner Tube: Schritt 8, Bild 2 von 2
  9. Patching a Bicycle Tire Inner Tube: Schritt 9, Bild 1 von 1
    • Remove the tube by pushing the valve through the hole in the rim and pulling out completely.
  10. Patching a Bicycle Tire Inner Tube: Schritt 10, Bild 1 von 2 Patching a Bicycle Tire Inner Tube: Schritt 10, Bild 2 von 2
    • Locate the leak by first over inflating the tire.
    • Place the tire under water and look for bubbles to find the leak.
  11. Patching a Bicycle Tire Inner Tube: Schritt 11, Bild 1 von 1
    • Mark the hole with a marker, and completely deflate the tire.
  12. Patching a Bicycle Tire Inner Tube: Schritt 12, Bild 1 von 1
    • Select a patch kit that you will use to patch the hole. Try to pick a patch that is appropriate for the size of the hole.
  13. Patching a Bicycle Tire Inner Tube: Schritt 13, Bild 1 von 1
    • Clean the area near the hole with soap and water, then dry it thoroughly.
    • Rough up the area around the hole with an abrasive surface such as sand paper until the area around the leak loses its shine.
  14. Patching a Bicycle Tire Inner Tube: Schritt 14, Bild 1 von 1
    • Apply rubber cement to an area around the hole that is bigger than the patch to ensure that the patch bonds completely.
  15. Patching a Bicycle Tire Inner Tube: Schritt 15, Bild 1 von 1
    • Apply the patch to the area.
  16. Patching a Bicycle Tire Inner Tube: Schritt 16, Bild 1 von 1
    • Apply pressure to the patch until the rubber cement is dry.
Abschluss
To reassemble your wheel, follow these instructions in reverse order starting at step three.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Travis Tonder
3.175 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 5-13, Maness Fall 2010 Mitglied von Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 4,111
