Zum Hauptinhalt wechseln
Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement
Was du brauchst
  1. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: Schritt 2, Bild 1 von 1
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: Schritt 3, Bild 1 von 1
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, Rear Casing: Schritt 4, Bild 1 von 1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: Schritt 5, Bild 1 von 1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: Schritt 6, Bild 1 von 2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: Schritt 6, Bild 2 von 2
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: Schritt 7, Bild 1 von 1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: Schritt 8, Bild 1 von 1
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: Schritt 9, Bild 1 von 2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: Schritt 9, Bild 2 von 2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, LCD Screen: Schritt 10, Bild 1 von 1
    • Gently lift up the LCD screen.
    • Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
    • It should fall out on its own or with a gentle tug.
  11. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: Schritt 11, Bild 1 von 1
    • Gently tug the thicker ribbon to remove it from its housing.
  12. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, On/ Off Button and Settings Button: Schritt 12, Bild 1 von 2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, On/ Off Button and Settings Button: Schritt 12, Bild 2 von 2
    • Carefully remove the upper assembly, which houses the buttons and the flash battery.
  13. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: Schritt 13, Bild 1 von 1
    • Remove the two 3mm screws.
  14. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: Schritt 14, Bild 1 von 2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: Schritt 14, Bild 2 von 2
    • Pry bars back gently as shown.
    • Fingers can be used but tool is shown for clarity.
  15. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: Schritt 15, Bild 1 von 2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: Schritt 15, Bild 2 von 2
    • After, releasing all the components, gently remove the flash assembly from the casing.
  16. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: Schritt 16, Bild 1 von 1
    • Remove the 1.2 mm screw from the settings wheel.
  17. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: Schritt 17, Bild 1 von 1
    • Replace buttons.
    • Replace the "On/ Off" button with the prongs facing away from the flash.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Andrew
396 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 9-22, Regan Fall 2010 Mitglied von Cal Poly, Team 9-22, Regan Fall 2010
CPSU-REGAN-F10S9G22
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Olá ! Sugiro ter cuidado com a carga do capacitor do flash, melhor descarrega-lo com auxílio de uma lâmpada ou resistor
para evitar um choque elétrico.
Ricardo Britto - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 5,068
