Zum Hauptinhalt wechseln
Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement
Was du brauchst
Einführungsvideo
  1. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement, Touch screen / Digitizer, LCD Display: Schritt 1, Bild 1 von 2 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement, Touch screen / Digitizer, LCD Display: Schritt 1, Bild 2 von 2
    • Switch off the phone and remove the battery.
  2. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: Schritt 2, Bild 1 von 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: Schritt 2, Bild 2 von 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: Schritt 2, Bild 3 von 3
    • Remove 8x Torx T5 screws.
    • With a plastic tool, start with separating the middle frame from the down side.
  3. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: Schritt 3, Bild 1 von 2 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: Schritt 3, Bild 2 von 2
    • The Loudspeaker is on the middle frame.
    • Disconnect the LCD Display flex cable.
    • Disconnect the Touch screen flex cable.
  4. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: Schritt 4, Bild 1 von 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: Schritt 4, Bild 2 von 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: Schritt 4, Bild 3 von 3
    • The Logic board is held by 2x locking clips at the bottom side.
    • Release it and gently remove it from the front frame.
  5. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: Schritt 5, Bild 1 von 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: Schritt 5, Bild 2 von 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: Schritt 5, Bild 3 von 3
    • Put tape on the glass to not scatter pieces.
    • Worm the glass to melt the adhesive.
    • Use plastic tools to separate the touchscreen from the frame.
  6. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: Schritt 6, Bild 1 von 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: Schritt 6, Bild 2 von 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: Schritt 6, Bild 3 von 3
    • After separating, clean up the sticker that remains on the borders.
    • New line.Install the new touchscreen and reassemble the device.
  7. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: Schritt 7, Bild 1 von 1
    • That's all.
    • Did you do it successfully?
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.368 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
321 Mitglieder
1.466 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 1,882
