Zum Hauptinhalt wechseln
BlackBerry Z30 Logic board Replacement
Was du brauchst
  1. BlackBerry Z30 Logic board Replacement, Battery cover: Schritt 1, Bild 1 von 1
    • Remove the battery cover by grabbing the notch under the bottom speakers and lifting.
  2. BlackBerry Z30 Logic board Replacement, Remove SIM and Media Card: Schritt 2, Bild 1 von 1
    • Remove the SIM card and the Media SD card by pushing on them.
  3. BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: Schritt 3, Bild 1 von 3 BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: Schritt 3, Bild 2 von 3 BlackBerry Z30 Logic board Replacement, Unscrewing the LCD panel: Schritt 3, Bild 3 von 3
    • Locate and unscrew all 10 T5 screws around the back cover
  4. BlackBerry Z30 Logic board Replacement, Separate the LCD from the Frame: Schritt 4, Bild 1 von 2 BlackBerry Z30 Logic board Replacement, Separate the LCD from the Frame: Schritt 4, Bild 2 von 2
    • Use Plastic opening tools to separate the LCD from the Main body
    • Do NOT remove the screen yet, it is attached with a very fragile ribbon to the main board.
    • Start on the same side of the Audio Jack
  5. BlackBerry Z30 Logic board Replacement, Remove the LCD: Schritt 5, Bild 1 von 2 BlackBerry Z30 Logic board Replacement, Remove the LCD: Schritt 5, Bild 2 von 2
    • Use a plastic tool to carefully switch up the LCD ribbon holder
    • Detach the LCD from the main board
    • When installing the new LCD, make sure the ribbon is inserted to the white line.
  6. BlackBerry Z30 Logic board Replacement, LCD Panel removal: Schritt 6, Bild 1 von 1
    • You can now detach the LCD Panel from the main frame.
  7. BlackBerry Z30 Logic board Replacement, Untie the System board: Schritt 7, Bild 1 von 1
    • With a plastic tool, untie the system board by detaching the ribbons attached to it
    • The battery ribbon is on the bottom right
    • Be gentle when detaching these Ribbons as they are very easy to tear and damage.
  8. BlackBerry Z30 Logic board Replacement, Untie the System board Part 2: Schritt 8, Bild 1 von 1
    • Be gentle as any other system board ribbons, they are very easy to damage
  9. BlackBerry Z30 Logic board Replacement, Untie the system board Part 3: Schritt 9, Bild 1 von 1
    • Power Button /Audio Jack
    • Flash
    • Rear Facing Camera
  10. BlackBerry Z30 Logic board Replacement, System board removal: Schritt 10, Bild 1 von 1
    • Once all Ribbons untied, gently wiggle the system board out of the frame
    • Do not pull hard as there might be a ribbon on the way
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Hans
1.920 Reputation
6 Anleitungen geschrieben
Mero IT Services Mitglied von Mero IT Services
Business
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 4,002
