Zum Hauptinhalt wechseln
Gateway MD2614u Battery Replacement
  1. Gateway MD2614u Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure the laptop is completely powered off and disconnected from any power source. Turn your Gateway MD2614U laptop over as shown in the image.
  2. Gateway MD2614u Battery Replacement: Schritt 2, Bild 1 von 1
    • 2. Find the laptop battery release button lock for your Gateway MD2614U laptop.
  3. Gateway MD2614u Battery Replacement: Schritt 3, Bild 1 von 1
    • Holding the laptop battery release button, gently pull your battery away from the laptop.
  4. Gateway MD2614u Battery Replacement: Schritt 4, Bild 1 von 1
    • Insert the new battery into the slot. Push the Gateway MD2614U battery towards the laptop and secure it in place.
Abschluss
To reassemble your Gateway MD2614u laptop after replacing the battery, follow the reverse sequence of the steps you took during the initial battery assembly.
Toni Pipes
333 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 21-31, Regan Fall 2010 Mitglied von Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 3,882
