Einleitung
This guide will show you how to remove the ThinkPad's upper case.
Was du brauchst
Slide the highlighted tab to the left.
With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
Remove the highlighted screw with a Phillips #1 screwdriver.
Pull the hard drive out.
Rotate the ThinkPad so that the hard drive bay is facing you.
Remove the black cover to reveal a 14.8mm screw.
Remove the uncovered screw with a Phillips #0 screwdriver.
Lift the front end of the keyboard as shown.
Using your fingers, remove the black film cover.
Locate the connector attached to the motherboard.
Disconnect the ribbon cable by removing the connector.
Lift and remove the keyboard.
Remove the two 5.6mm screws.
Remove the 16.7mm screw.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
