Einleitung
This guide will show how to remove the speaker.
Was du brauchst
To remove the back cover, use your thumb to press down on the center of case and slide it off.
To remove the back case first remove the four screws shown with a T5 Torx screwdriver
Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
Use a plastic opening tool to lift the speaker out of the back case.
