Zum Hauptinhalt wechseln
Onda V701 Screen Replacement
Was du brauchst
  1. Onda V701 Screen Replacement, Back Panel: Schritt 1, Bild 1 von 3 Onda V701 Screen Replacement, Back Panel: Schritt 1, Bild 2 von 3 Onda V701 Screen Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Ensure device is powered off before disassembly.
    • Remove the 4 rubber screw plugs using a spudger.
  2. Onda V701 Screen Replacement: Schritt 2, Bild 1 von 3 Onda V701 Screen Replacement: Schritt 2, Bild 2 von 3 Onda V701 Screen Replacement: Schritt 2, Bild 3 von 3
    • Remove the four 4.8mm mounting screws using a PH00 screwdriver.
  3. Onda V701 Screen Replacement: Schritt 3, Bild 1 von 2 Onda V701 Screen Replacement: Schritt 3, Bild 2 von 2
    • Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
    • Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
  4. Onda V701 Screen Replacement: Schritt 4, Bild 1 von 2 Onda V701 Screen Replacement: Schritt 4, Bild 2 von 2
    • Gently lift the screen assembly away from the back cover assembly.
    • Be careful when separating the two pieces as the screen assembly is still connected to the mother board by two ribbon cables.
  5. Onda V701 Screen Replacement: Schritt 5, Bild 1 von 3 Onda V701 Screen Replacement: Schritt 5, Bild 2 von 3 Onda V701 Screen Replacement: Schritt 5, Bild 3 von 3
    • Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
    • Remove the ribbon cables.
  6. Onda V701 Screen Replacement, Screen: Schritt 6, Bild 1 von 3 Onda V701 Screen Replacement, Screen: Schritt 6, Bild 2 von 3 Onda V701 Screen Replacement, Screen: Schritt 6, Bild 3 von 3
    • Remove all 14 of the 3.6mm screws using a PH00 screwdriver.
  7. Onda V701 Screen Replacement: Schritt 7, Bild 1 von 3 Onda V701 Screen Replacement: Schritt 7, Bild 2 von 3 Onda V701 Screen Replacement: Schritt 7, Bild 3 von 3
    • Gently separate the screen from the plastic border/screen holder by pulling it off with your hands.
  8. Onda V701 Screen Replacement: Schritt 8, Bild 1 von 3 Onda V701 Screen Replacement: Schritt 8, Bild 2 von 3 Onda V701 Screen Replacement: Schritt 8, Bild 3 von 3
    • Remove the grey monitor from the glass screen cover by gently lifting it up.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Colorado Springs, Team 4-6, Panko Spring 2015 Mitglied von Colorado Springs, Team 4-6, Panko Spring 2015
UCCS-PANKO-S15S4G6
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
بدي من هي الشاشة وين بلاقي
abdurrhman khrrat - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 459
