Zum Hauptinhalt wechseln
Canon EOS Rebel T2i Hot Shoe Replacement
Was du brauchst
  1. Canon EOS Rebel T2i Hot Shoe Replacement, Hot Shoe: Schritt 1, Bild 1 von 3 Canon EOS Rebel T2i Hot Shoe Replacement, Hot Shoe: Schritt 1, Bild 2 von 3 Canon EOS Rebel T2i Hot Shoe Replacement, Hot Shoe: Schritt 1, Bild 3 von 3
    • Using the flat end of the spudger, carefully pry the rear part of the hot shoe baseplate upward.
    • Pull the spudger backwards to remove the base plate.
    • Removing this plate reveals the mounting screws for the hot shoe.
  2. Canon EOS Rebel T2i Hot Shoe Replacement: Schritt 2, Bild 1 von 1
    • To remove the hot shoe, unscrew the 4 mounting screws holding it in place.
  3. Canon EOS Rebel T2i Hot Shoe Replacement: Schritt 3, Bild 1 von 1
    • With the screws removed, the hot shoe can now be lifted out of place.
Abschluss
To reassemble your device, follow these instructions in reverse order. When tightening screws that hold the hot shoe in place, be very careful to not scratch the rail of the hot shoe. If the rail of the hot shoe has any scratches or dents, it can be more difficult to mount the external flash.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jacob Jaskolka
745 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 1-1, Shastany Spring 2015 Mitglied von UMass Dartmouth, Team 1-1, Shastany Spring 2015
UMASSD-SHASTANY-S15S1G1
3 Mitglieder
Ein Kommentar
My hot shoe actually came off. I have ordered various sizes of screws to replace it but none work. I need a new hot shoe and screws. What size screws do I need with a canon rebel T2i camera?
Cindy Mitchum - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 35
Insgesamt: 5,640
