Zum Hauptinhalt wechseln
Nokia 6085h Front LCD Display
Was du brauchst
  1. Nokia 6085h Front LCD Display, Battery: Schritt 1, Bild 1 von 1
    • Flip over the phone so that the back is facing up.
    • Pressing your thumb against the back cover, slide the cover off of the phone.
  2. Nokia 6085h Front LCD Display: Schritt 2, Bild 1 von 1
    • Remove the phone's battery.
  3. Nokia 6085h Front LCD Display, Front LCD Display: Schritt 3, Bild 1 von 3 Nokia 6085h Front LCD Display, Front LCD Display: Schritt 3, Bild 2 von 3 Nokia 6085h Front LCD Display, Front LCD Display: Schritt 3, Bild 3 von 3
    • With the phone closed, run a plastic opening tool along the seam of the top half of the phone.
    • Make sure to disconnect each of the five clips before proceeding to the next step.
    • There are two clips on each side of the phone and one on the top.
  4. Nokia 6085h Front LCD Display: Schritt 4, Bild 1 von 2 Nokia 6085h Front LCD Display: Schritt 4, Bild 2 von 2
    • Remove the four 3.2 mm screws from the front panel using a T6 Torx screwdriver.
    • The fourth screw is located under a fold in the ribbon cable.
  5. Nokia 6085h Front LCD Display: Schritt 5, Bild 1 von 3 Nokia 6085h Front LCD Display: Schritt 5, Bild 2 von 3 Nokia 6085h Front LCD Display: Schritt 5, Bild 3 von 3
    • Starting in the lower right corner, slowly begin to lift the tape that is holding down the front LCD and cables.
    • Be careful around the two ribbon cables attached to the tape. These cables are fragile.
    • Lift the tape from the board.
  6. Nokia 6085h Front LCD Display: Schritt 6, Bild 1 von 1
    • Using a plastic opening tool, lift the ribbon cable connection below the front LCD.
  7. Nokia 6085h Front LCD Display: Schritt 7, Bild 1 von 3 Nokia 6085h Front LCD Display: Schritt 7, Bild 2 von 3 Nokia 6085h Front LCD Display: Schritt 7, Bild 3 von 3
    • Using a plastic opening tool, slowly pry the LCD display from the bottom, releasing it from the glue that is holding it to the board.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Brett Balcer
240 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 4-46, Amido Fall 2010 Mitglied von Cal Poly, Team 4-46, Amido Fall 2010
CPSU-AMIDO-F10S4G46
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 1,101
