Zum Hauptinhalt wechseln
Bose SoundDock Portable v2 Speaker Replacement
Was du brauchst
  1. Bose SoundDock Portable v2 Speaker Replacement, Speaker: Schritt 1, Bild 1 von 3 Bose SoundDock Portable v2 Speaker Replacement, Speaker: Schritt 1, Bild 2 von 3 Bose SoundDock Portable v2 Speaker Replacement, Speaker: Schritt 1, Bild 3 von 3
    • Gently pry the front mesh cover off of the SoundDock using a metal spudger.
    • The mesh is held on by small velcro strips so if you hear a tearing sound it is just the velcro coming apart
  2. Bose SoundDock Portable v2 Speaker Replacement: Schritt 2, Bild 1 von 2 Bose SoundDock Portable v2 Speaker Replacement: Schritt 2, Bild 2 von 2
    • Remove the four 16mm #2 screws holding the speaker to the base using a #2 screwdriver
    • Gently lift the speaker from the base.
    • Do not lift the speaker to far out of the base, you may damage the wires.
  3. Bose SoundDock Portable v2 Speaker Replacement: Schritt 3, Bild 1 von 1
    • You will notice 2 coils of wire around the speaker's input tabs. Slide these coils off as un-winding the wires may break the wires. Slide the coils around your new driver.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Evan Low
551 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 4-1, Maness Spring 2015 Mitglied von Cal Poly, Team 4-1, Maness Spring 2015
CPSU-MANESS-S15S4G1
4 Mitglieder
5 Anleitungen geschrieben
5 Kommentare
I am unsure of what to do in step #3…
Is the purpose to remove the speaker completely and place a brand new one? (Making sure not to pull the old speaker too far out as to not break any wire… ) ???
Edited comment:
I am not sure what they mean by "pins".
vero198099 - Antwort
Hi I just accidently pushed in that dome part in the middle a little and now it distorts. I tried using a vacuum but it didnt work. Please help!!!!!!!!
AJ Grape - Antwort
Try to see if there’s any way you can reduce the nozzle size of the vacuum cleaner you’re using - this should increase the flow rate, and possibly the amount of force applied over such a small area.
Alternatively, you can use a very very fine needle, bend the end of it, and use it to “hook” the cone. This method is really a last resort, as you want to avoid making even the smallest of holes.
Absolute last resort is replacing the speaker, which if you can find a replacement, should be pretty easy.
Colm Donnelly -
Need help love this speaker when it’s played loud it makes a load noise when the base is on changed aux lead think it’s the speaker what do I do
Chantelle Webb - Antwort
How do you cut on without remote
Chad Davenport - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 29
Insgesamt: 11,703
