Zum Hauptinhalt wechseln
Disassembling IBM ThinkPad A30 Display Assembly
Was du brauchst
  1. Disassembling IBM ThinkPad A30 Display Assembly, Battery: Schritt 1, Bild 1 von 2 Disassembling IBM ThinkPad A30 Display Assembly, Battery: Schritt 1, Bild 2 von 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 Display Assembly, Hard Drive: Schritt 2, Bild 1 von 3 Disassembling IBM ThinkPad A30 Display Assembly, Hard Drive: Schritt 2, Bild 2 von 3 Disassembling IBM ThinkPad A30 Display Assembly, Hard Drive: Schritt 2, Bild 3 von 3
    • Remove the highlighted screw with a Phillips #1 screwdriver.
    • Pull the hard drive out.
  3. Disassembling IBM ThinkPad A30 Display Assembly, Upper Case: Schritt 3, Bild 1 von 1
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
  4. Disassembling IBM ThinkPad A30 Display Assembly: Schritt 4, Bild 1 von 1
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
  5. Disassembling IBM ThinkPad A30 Display Assembly: Schritt 5, Bild 1 von 2 Disassembling IBM ThinkPad A30 Display Assembly: Schritt 5, Bild 2 von 2
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
  6. Disassembling IBM ThinkPad A30 Display Assembly: Schritt 6, Bild 1 von 3 Disassembling IBM ThinkPad A30 Display Assembly: Schritt 6, Bild 2 von 3 Disassembling IBM ThinkPad A30 Display Assembly: Schritt 6, Bild 3 von 3
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
  7. Disassembling IBM ThinkPad A30 Display Assembly: Schritt 7, Bild 1 von 3 Disassembling IBM ThinkPad A30 Display Assembly: Schritt 7, Bild 2 von 3 Disassembling IBM ThinkPad A30 Display Assembly: Schritt 7, Bild 3 von 3
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
  8. Disassembling IBM ThinkPad A30 Display Assembly: Schritt 8, Bild 1 von 2 Disassembling IBM ThinkPad A30 Display Assembly: Schritt 8, Bild 2 von 2
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
  9. Disassembling IBM ThinkPad A30 Display Assembly: Schritt 9, Bild 1 von 3 Disassembling IBM ThinkPad A30 Display Assembly: Schritt 9, Bild 2 von 3 Disassembling IBM ThinkPad A30 Display Assembly: Schritt 9, Bild 3 von 3
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
  10. Disassembling IBM ThinkPad A30 Display Assembly, Display Assembly: Schritt 10, Bild 1 von 1
    • Remove the 5.6mm screw that holds the LCD to the upper case.
  11. Disassembling IBM ThinkPad A30 Display Assembly: Schritt 11, Bild 1 von 3 Disassembling IBM ThinkPad A30 Display Assembly: Schritt 11, Bild 2 von 3 Disassembling IBM ThinkPad A30 Display Assembly: Schritt 11, Bild 3 von 3
    • Remove the 5.6mm screw on the left side of the three-pronged connector.
    • Remove the other two 16.7mm screws.
    • Lift and remove connector.
  12. Disassembling IBM ThinkPad A30 Display Assembly: Schritt 12, Bild 1 von 2 Disassembling IBM ThinkPad A30 Display Assembly: Schritt 12, Bild 2 von 2
    • Pull out the white tab connecting the LCD to the motherboard.
  13. Disassembling IBM ThinkPad A30 Display Assembly: Schritt 13, Bild 1 von 2 Disassembling IBM ThinkPad A30 Display Assembly: Schritt 13, Bild 2 von 2
    • Turn the laptop so that the back is facing you.
    • Remove the four 5.6mm long screws.
  14. Disassembling IBM ThinkPad A30 Display Assembly: Schritt 14, Bild 1 von 3 Disassembling IBM ThinkPad A30 Display Assembly: Schritt 14, Bild 2 von 3 Disassembling IBM ThinkPad A30 Display Assembly: Schritt 14, Bild 3 von 3
    • Place the laptop so that the LCD is facing you again.
    • Gently lift the LCD monitor up and out.
    • Remove the black plastic tab.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jessica
162 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 4-44, Amido Fall 2010 Mitglied von Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Mitglieder
26 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 11
Insgesamt: 3,412
