Zum Hauptinhalt wechseln
Disassembling IBM ThinkPad A30 Modem and Ethernet Cards
Was du brauchst
  1. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Battery: Schritt 1, Bild 1 von 2 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Battery: Schritt 1, Bild 2 von 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Modem and Ethernet Cards: Schritt 2, Bild 1 von 2 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards, Modem and Ethernet Cards: Schritt 2, Bild 2 von 2
    • Remove the two 5.3mm cover screws.
    • Gently lift the cover.
  3. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: Schritt 3, Bild 1 von 1
    • Remove the four 9.1mm screws attached to the ethernet and modem cards.
  4. Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: Schritt 4, Bild 1 von 3 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: Schritt 4, Bild 2 von 3 Disassembling IBM ThinkPad A30 Modem and Ethernet Cards: Schritt 4, Bild 3 von 3
    • When lifting the cards, be careful not to rip out the cables!
    • Gently lift the modem and ethernet cards.
    • Remove the cables that attach the modem and ethernet cards.
Abschluss
Alan
380 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 4-44, Amido Fall 2010 Mitglied von Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Mitglieder
26 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 23
Insgesamt: 1,904
