Einleitung
Use this guide to replace the midframe on your Nikon Coolpix S6800.
Was du brauchst
Turn the camera upside down and locate the two, black screws.
Using the Philips #00 Screwdriver, remove each screw.
Rotate the camera to the left side and remove the two, black, #00 Philips screws.
Rotate the camera to the right side and remove the two, black, #00 Philips screws.
Using the Philips #00 Screwdriver, remove the two screws that are holding the keypad.
Gently pull the display away from the camera body.
Fold the display away from the camera
Remove the visible midframe screws.
There is a screw beneath the foam square that must be removed as well.
The screw holding the silver wrist-strap loop on the side of the camera must also be removed.
Gently lift the midframe up and out of the device.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
