Zum Hauptinhalt wechseln
Disassembling Kinivo ZX100 Mini Portable Speaker
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Disassembling Kinivo ZX100 Mini Portable Speaker, Disassembling Kinivo ZX100 Mini Portable Speaker: Schritt 1, Bild 1 von 1
    • Open the circular portion at the top of the speaker by twisting it until it reaches the maximum possible height.
    • Make sure it is twisted fully, as this will allow access to four screws to be removed in the next step.
  2. Disassembling Kinivo ZX100 Mini Portable Speaker: Schritt 2, Bild 1 von 2 Disassembling Kinivo ZX100 Mini Portable Speaker: Schritt 2, Bild 2 von 2
    • Remove the four 12 mm Phillips screws from the enclosure.
  3. Disassembling Kinivo ZX100 Mini Portable Speaker: Schritt 3, Bild 1 von 2 Disassembling Kinivo ZX100 Mini Portable Speaker: Schritt 3, Bild 2 von 2
    • Separate the resonator portion from the base of device to reveal the middle separator of the enclosure. The enclosure will now be in two pieces.
    • Hold the resonator portion of the enclosure gently aside to make sure there is no tension on the black and red wires coming from the bottom portion of the device.
    • Excessive force may disconnect the black and red speaker wires from the circuitry in the bottom portion of the device.
  4. Disassembling Kinivo ZX100 Mini Portable Speaker: Schritt 4, Bild 1 von 1
    • Separate the very bottom portion of the enclosure (marked in red) by pulling vertically on the red portion of the enclosure (marked in orange).
    • Gently set the very bottom portion and the resonator section aside once they have both been separated.
    • Remove the circuit board with your hands by lifting and sliding the board away from the LED indicator.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Laura Dion
143 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 1-5, Shastany Spring 2015 Mitglied von UMass Dartmouth, Team 1-5, Shastany Spring 2015
UMASSD-SHASTANY-S15S1G5
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 79
