Zum Hauptinhalt wechseln
Dell Photo Printer 720 Encoder Strip Replacement
Was du brauchst
  1. Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: Schritt 1, Bild 1 von 3 Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: Schritt 1, Bild 2 von 3 Dell Photo Printer 720 Encoder Strip Replacement, Encoder Strip: Schritt 1, Bild 3 von 3
    • Use a Phillips head #2 screwdriver to remove the 4 screws located on the bottom of the Dell Photo Printer 720.
  2. Dell Photo Printer 720 Encoder Strip Replacement: Schritt 2, Bild 1 von 3 Dell Photo Printer 720 Encoder Strip Replacement: Schritt 2, Bild 2 von 3 Dell Photo Printer 720 Encoder Strip Replacement: Schritt 2, Bild 3 von 3
    • Use a spudger to wedge between the cover and base of the printer (where the light grey and black portions meet).
    • Pry apart the light grey cover from the black base.
    • Gently flip the printer upright to its standard position and carefully lift off the cover.
  3. Dell Photo Printer 720 Encoder Strip Replacement: Schritt 3, Bild 1 von 2 Dell Photo Printer 720 Encoder Strip Replacement: Schritt 3, Bild 2 von 2
    • Slide the ink cartridge from the right side to the middle left so it is out of the way.
  4. Dell Photo Printer 720 Encoder Strip Replacement: Schritt 4, Bild 1 von 3 Dell Photo Printer 720 Encoder Strip Replacement: Schritt 4, Bild 2 von 3 Dell Photo Printer 720 Encoder Strip Replacement: Schritt 4, Bild 3 von 3
    • Grab ahold of the encoder strip on the right side. Gently tug the strip outward and swing the end piece towards you to unhook the encoder from the prong.
    • Carefully unhook the opposite end of the encoder strip to full disconnect the part.
    • To replace new encoder strip, reattach each end to the hooks by reversing previous steps.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Megan Lawrence
534 Reputation
5 Anleitungen geschrieben
USF Sarasota-Manatee, Team 1-3, Stewart Winter 2015 Mitglied von USF Sarasota-Manatee, Team 1-3, Stewart Winter 2015
USFSM-STEWART-W15S1G3
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 7
Insgesamt: 493
