Zum Hauptinhalt wechseln
Canon PowerShot SD850 IS Motherboard Replacement
Was du brauchst
  1. Canon PowerShot SD850 IS Motherboard Replacement, Battery: Schritt 1, Bild 1 von 3 Canon PowerShot SD850 IS Motherboard Replacement, Battery: Schritt 1, Bild 2 von 3 Canon PowerShot SD850 IS Motherboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 2, Bild 1 von 2 Canon PowerShot SD850 IS Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
  3. Canon PowerShot SD850 IS Motherboard Replacement, Case: Schritt 3, Bild 1 von 2 Canon PowerShot SD850 IS Motherboard Replacement, Case: Schritt 3, Bild 2 von 2
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 4, Bild 1 von 3 Canon PowerShot SD850 IS Motherboard Replacement: Schritt 4, Bild 2 von 3 Canon PowerShot SD850 IS Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 5, Bild 1 von 2 Canon PowerShot SD850 IS Motherboard Replacement: Schritt 5, Bild 2 von 2
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  6. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 6, Bild 1 von 2 Canon PowerShot SD850 IS Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  7. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  8. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  9. Canon PowerShot SD850 IS Motherboard Replacement, LCD Screen: Schritt 9, Bild 1 von 1
    • Remove the 1.75 mm Phillips #00 located at the top left of the LCD screen.
  10. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Remove the two 3.4 mm Phillips #00 located at the bottom of the camera.
  11. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 11, Bild 1 von 2 Canon PowerShot SD850 IS Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Remove the two metal frames that hold the LCD panel in place.
  12. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 12, Bild 1 von 1
    • The LCD screen should now only be attached by two LCD data cables.
    • Lift the screen from the left side and use a spudger or a small flat head screwdriver to flip the black portion of the connector upward to unlock it.
    • Carefully slide the data cable out of the connector.
  13. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 13, Bild 1 von 1
    • The LCD should still be connected by the backlight cable.
    • To remove the backlight cable, use a spudger or a small flat head screwdriver to unlock the backlight cable.
    • Carefully slide out the backlight cable.
    • The LCD screen can now be fully detached from the camera body.
  14. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 14, Bild 1 von 2 Canon PowerShot SD850 IS Motherboard Replacement: Schritt 14, Bild 2 von 2
    • The LCD screen and housing are now in three pieces:
    • LCD screen
    • LCD screen frame
    • LCD back housing
    • The LCD screen itself can now be removed and fixed/replaced.
  15. Canon PowerShot SD850 IS Motherboard Replacement, Flash Unit: Schritt 15, Bild 1 von 1
    • Remove the 1.85 mm #00 Phillips located on the left side of the camera.
  16. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 16, Bild 1 von 2 Canon PowerShot SD850 IS Motherboard Replacement: Schritt 16, Bild 2 von 2
    • Use a set of tweezers to remove the speaker located at the top of the camera on the flash unit.
    • Next use the tweezers to carefully remove the speaker cable off its respective holders.
  17. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 17, Bild 1 von 1
    • Use a spudger or a flathead screwdriver to remove the camera lens cable located in the front of the camera.
  18. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 18, Bild 1 von 2 Canon PowerShot SD850 IS Motherboard Replacement: Schritt 18, Bild 2 von 2
    • Use a spudger or a flathead screwdriver and carefully pry out the first flash cable from the bottom of the cable. The white 2 prong power cable pops UP (use spudger below red/black insertion and put upward pressure). For the yellow one, apply pressure horizontally.
    • Next use a spudger or a flathead screwdriver and carefully pry out the second flash cable.
  19. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 19, Bild 1 von 1
    • Gently remove the flash component from the rest of the camera.
    • Use a spudger or a flathead screwdriver and carefully pry off the plastic piece on top of the flash unit.
    • The flash unit can now be removed and replaced.
    • Be careful not to touch the capacitor attached to the flash unit as it may still be holding a charge!
  20. Canon PowerShot SD850 IS Motherboard Replacement, Camera Lens: Schritt 20, Bild 1 von 1
    • Remove four screws located on the back of the camera:
    • 6.15 mm #00 Phillips
    • 2.75 mm #00 Phillips
    • 2.15 mm #00 Phillips
    • 2.7 mm #00 Phillips
  21. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 21, Bild 1 von 1
    • Use a spudger or a flathead screwdriver and carefully pry out the bulb located in the front of the camera on top of the camera lens.
  22. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 22, Bild 1 von 1
    • Gently remove the camera lens from the rest of the camera.
  23. Canon PowerShot SD850 IS Motherboard Replacement, Motherboard: Schritt 23, Bild 1 von 1
    • Remove the 2.6 mm Phillips #00 located near the shutter release button.
  24. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 24, Bild 1 von 2 Canon PowerShot SD850 IS Motherboard Replacement: Schritt 24, Bild 2 von 2
    • Use a prying device or your fingers to release the ribbon from its holder.
    • Gently remove the shutter release component from the camera.
  25. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 25, Bild 1 von 2 Canon PowerShot SD850 IS Motherboard Replacement: Schritt 25, Bild 2 von 2
    • Remove the 3.4 mm Phillips #00 located under the camera.
    • Next use a prying device or your fingers to release the power trigger cable from its holder.
  26. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 26, Bild 1 von 1
    • Use a prying device or your fingers to release the ribbon from their respective holders located at the top of the camera.
  27. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 27, Bild 1 von 2 Canon PowerShot SD850 IS Motherboard Replacement: Schritt 27, Bild 2 von 2
    • Use a spudger or a flathead screwdriver to unlock the ribbon located at the back of the camera.
    • Then gently slide out the ribbon.
  28. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 28, Bild 1 von 1
    • The whole ribbon and metal casing can now be easily removed from the remains of the camera.
  29. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 29, Bild 1 von 1
    • Use a spudger or a flathead screwdriver to release the motherboard cable.
  30. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 30, Bild 1 von 1
    • Next remove the 3.4 mm Phillips #00 located in front of the camera. wisdom here.
  31. Canon PowerShot SD850 IS Motherboard Replacement: Schritt 31, Bild 1 von 1
    • Now the motherboard can be gently removed from the metal casing.
Abschluss
Peter Tran
225 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 20-7, Maness Fall 2010 Mitglied von Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 13
Insgesamt: 2,801
