Zum Hauptinhalt wechseln
PowerBook G3 Lombard Heat Shield Replacement
Was du brauchst
  1. PowerBook G3 Lombard Heat Shield Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard Heat Shield Replacement: Schritt 2, Bild 1 von 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard Heat Shield Replacement: Schritt 3, Bild 1 von 1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard Heat Shield Replacement, Heat Shield: Schritt 4, Bild 1 von 1
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  5. PowerBook G3 Lombard Heat Shield Replacement: Schritt 5, Bild 1 von 1
    • Lift the heat shield up and pull it toward you.
  6. PowerBook G3 Lombard Heat Shield Replacement: Schritt 6, Bild 1 von 1
    • Your laptop should look approximately like this.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Angehängte Dokumente
iRobot
1 Reputation
636 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 2,551
