Zum Hauptinhalt wechseln
Lenovo Miix 2 Battery Replacement
Was du brauchst
  1. Lenovo Miix 2 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Lenovo Miix 2 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
    • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
  2. Lenovo Miix 2 Battery Replacement: Schritt 2, Bild 1 von 2 Lenovo Miix 2 Battery Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
  3. Lenovo Miix 2 Battery Replacement: Schritt 3, Bild 1 von 2 Lenovo Miix 2 Battery Replacement: Schritt 3, Bild 2 von 2
    • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
  4. Lenovo Miix 2 Battery Replacement: Schritt 4, Bild 1 von 2 Lenovo Miix 2 Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the battery by prying up with your fingers or a plastic opening tool.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 5-8, Maness Spring 2015 Mitglied von Cal Poly, Team 5-8, Maness Spring 2015
CPSU-MANESS-S15S5G8
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 22
Insgesamt: 8,887
