Zum Hauptinhalt wechseln
Acer Aspire 5100 LCD Monitor Replacement
Was du brauchst
  1. Acer Aspire 5100 LCD Monitor Replacement, Keyboard: Schritt 1, Bild 1 von 2 Acer Aspire 5100 LCD Monitor Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 LCD Monitor Replacement: Schritt 2, Bild 1 von 3 Acer Aspire 5100 LCD Monitor Replacement: Schritt 2, Bild 2 von 3 Acer Aspire 5100 LCD Monitor Replacement: Schritt 2, Bild 3 von 3
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 LCD Monitor Replacement: Schritt 3, Bild 1 von 1
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
  4. Acer Aspire 5100 LCD Monitor Replacement, LCD Monitor: Schritt 4, Bild 1 von 1
    • Remove the two screws from each corner beneath the LCD screen.
  5. Acer Aspire 5100 LCD Monitor Replacement: Schritt 5, Bild 1 von 2 Acer Aspire 5100 LCD Monitor Replacement: Schritt 5, Bild 2 von 2
    • Detach the white rectangle located on the motherboard at the end of the wire connected to the LCD screen.
  6. Acer Aspire 5100 LCD Monitor Replacement: Schritt 6, Bild 1 von 2 Acer Aspire 5100 LCD Monitor Replacement: Schritt 6, Bild 2 von 2
    • Flip the laptop upside down.
    • Remove the four screws from the back panel of the laptop.
    • Lift the panel up and set it aside.
  7. Acer Aspire 5100 LCD Monitor Replacement: Schritt 7, Bild 1 von 1
    • Detach the black and white wire.
    • You do not need to remove the cooling fan.
  8. Acer Aspire 5100 LCD Monitor Replacement: Schritt 8, Bild 1 von 1
    • Lift up the monitor to detach it.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Brad Rollinson
1.113 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 14-39, Forte Fall 2010 Mitglied von Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
There are 2 screws at the back corners on the bottom cover that are holding the screen down. They need to be removed in order for the screen to be lifted.
Kar Wong - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 15,435
