Zum Hauptinhalt wechseln
MacBook Air 11" Late 2010 Logic Board Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. MacBook Air 11" Late 2010 Logic Board Replacement, Logic Board: Schritt 1, Bild 1 von 1
    • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  2. MacBook Air 11" Late 2010 Logic Board Replacement: Schritt 2, Bild 1 von 2 MacBook Air 11" Late 2010 Logic Board Replacement: Schritt 2, Bild 2 von 2
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
  3. MacBook Air 11" Late 2010 Logic Board Replacement: Schritt 3, Bild 1 von 1
    • Use the tip of a spudger to de-route the right speaker cable from the slot cut into the logic board.
  4. MacBook Air 11" Late 2010 Logic Board Replacement: Schritt 4, Bild 1 von 1
    • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
    • Pry up from beneath the cables.
  5. MacBook Air 11" Late 2010 Logic Board Replacement: Schritt 5, Bild 1 von 3 MacBook Air 11" Late 2010 Logic Board Replacement: Schritt 5, Bild 2 von 3 MacBook Air 11" Late 2010 Logic Board Replacement: Schritt 5, Bild 3 von 3
    • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
    • While holding the lock away from the socket, use the tip of a spudger and your fingers to gently remove the display data cable from its socket.
    • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
  6. MacBook Air 11" Late 2010 Logic Board Replacement: Schritt 6, Bild 1 von 1
    • Remove the small rubber gasket from the corner of the upper case near the display data cable.
  7. MacBook Air 11" Late 2010 Logic Board Replacement: Schritt 7, Bild 1 von 2 MacBook Air 11" Late 2010 Logic Board Replacement: Schritt 7, Bild 2 von 2
    • Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
  8. MacBook Air 11" Late 2010 Logic Board Replacement: Schritt 8, Bild 1 von 1
    • Gently de-route the antenna cables from the slot cut into the logic board.
  9. MacBook Air 11" Late 2010 Logic Board Replacement: Schritt 9, Bild 1 von 1
    • Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
  10. MacBook Air 11" Late 2010 Logic Board Replacement: Schritt 10, Bild 1 von 1
    • Gently lift the logic board assembly out of the upper case, minding the fragile heat sink and any cables that may get caught.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 341
