Zum Hauptinhalt wechseln
PowerBook G3 Lombard Processor Replacement
Was du brauchst
  1. PowerBook G3 Lombard Processor Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard Processor Replacement: Schritt 2, Bild 1 von 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard Processor Replacement: Schritt 3, Bild 1 von 1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard Processor Replacement, Heat Shield: Schritt 4, Bild 1 von 1
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  5. PowerBook G3 Lombard Processor Replacement: Schritt 5, Bild 1 von 1
    • Lift the heat shield up and pull it toward you.
  6. PowerBook G3 Lombard Processor Replacement: Schritt 6, Bild 1 von 1
    • Your laptop should look approximately like this.
  7. PowerBook G3 Lombard Processor Replacement, PRAM Battery: Schritt 7, Bild 1 von 1
    • Pull the battery cable directly up from the logic board.
  8. PowerBook G3 Lombard Processor Replacement: Schritt 8, Bild 1 von 1
    • Remove the battery from its holder by pulling up and to the left.
  9. PowerBook G3 Lombard Processor Replacement, Modem: Schritt 9, Bild 1 von 1
    • Remove the two silver Phillips screws from the modem.
  10. PowerBook G3 Lombard Processor Replacement: Schritt 10, Bild 1 von 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
  11. PowerBook G3 Lombard Processor Replacement: Schritt 11, Bild 1 von 1
    • Disconnect the cable from the right side of the modem.
  12. PowerBook G3 Lombard Processor Replacement: Schritt 12, Bild 1 von 1
  13. PowerBook G3 Lombard Processor Replacement, Processor: Schritt 13, Bild 1 von 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
  14. PowerBook G3 Lombard Processor Replacement: Schritt 14, Bild 1 von 1
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
  15. PowerBook G3 Lombard Processor Replacement: Schritt 15, Bild 1 von 1
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Angehängte Dokumente
iRobot
1 Reputation
636 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 15
Insgesamt: 5,842
