Zum Hauptinhalt wechseln
HP Mini 1000 RAM Replacement
Was du brauchst
  1. HP Mini 1000 RAM Replacement, Battery: Schritt 1, Bild 1 von 2 HP Mini 1000 RAM Replacement, Battery: Schritt 1, Bild 2 von 2
    • With the case closed, place the Mini 1000 top-side down on a flat surface.
    • Push both of the battery release latches toward each other.
  2. HP Mini 1000 RAM Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery out of the Mini 1000 from the edge closest to the release latches.
  3. HP Mini 1000 RAM Replacement, RAM: Schritt 3, Bild 1 von 2 HP Mini 1000 RAM Replacement, RAM: Schritt 3, Bild 2 von 2
    • Before proceeding, slide the right battery release latch to the unlocked position nearest the center of the computer.
    • Use the tip of a spudger to slide the RAM compartment cover release latch away from the center of the computer.
    • At this point, the edge of the RAM compartment cover nearest the battery compartment should pop up from the lower case.
  4. HP Mini 1000 RAM Replacement: Schritt 4, Bild 1 von 1
    • Remove the RAM compartment cover from the lower case.
  5. HP Mini 1000 RAM Replacement: Schritt 5, Bild 1 von 2 HP Mini 1000 RAM Replacement: Schritt 5, Bild 2 von 2
    • Use your fingers to simultaneously pull both RAM retaining arms away from the center of the RAM chip.
    • The RAM chip should pop up slightly from its socket.
    • Pull the RAM chip out of its socket and remove it from the Mini 1000.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 4,459
