Zum Hauptinhalt wechseln
Toilet Tank Assembly Replacement
Was du brauchst
  1. Toilet Tank Assembly Replacement, Tank Lid: Schritt 1, Bild 1 von 3 Toilet Tank Assembly Replacement, Tank Lid: Schritt 1, Bild 2 von 3 Toilet Tank Assembly Replacement, Tank Lid: Schritt 1, Bild 3 von 3
    • Lift the tank lid up and away from the toilet tank.
  2. Toilet Tank Assembly Replacement, Shutting off the Water Supply to a Toilet: Schritt 2, Bild 1 von 2 Toilet Tank Assembly Replacement, Shutting off the Water Supply to a Toilet: Schritt 2, Bild 2 von 2
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toilet Tank Assembly Replacement, Draining a Toilet Tank: Schritt 3, Bild 1 von 2 Toilet Tank Assembly Replacement, Draining a Toilet Tank: Schritt 3, Bild 2 von 2
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  4. Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: Schritt 4, Bild 1 von 3 Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: Schritt 4, Bild 2 von 3 Toilet Tank Assembly Replacement, Sponge Drying a Toilet Tank: Schritt 4, Bild 3 von 3
    • Use a sponge to soak up and remove any remaining water from the toilet tank.
    • Periodically squeeze the excess water from the sponge.
  5. Toilet Tank Assembly Replacement, Supply Tube: Schritt 5, Bild 1 von 3 Toilet Tank Assembly Replacement, Supply Tube: Schritt 5, Bild 2 von 3 Toilet Tank Assembly Replacement, Supply Tube: Schritt 5, Bild 3 von 3
    • Place a bucket under the supply tube to catch any dripping water.
    • Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
  6. Toilet Tank Assembly Replacement, Tank Assembly: Schritt 6, Bild 1 von 3 Toilet Tank Assembly Replacement, Tank Assembly: Schritt 6, Bild 2 von 3 Toilet Tank Assembly Replacement, Tank Assembly: Schritt 6, Bild 3 von 3
    • Using a socket wrench to hold the nuts, unscrew the two tank bolts with a screwdriver.
    • When reattaching the tank, tighten the bolts with a screwdriver, rather than tightening the nuts. Alternately tighten each bolt in increments, until the tank fits snugly against the toilet.
    • Avoid over-tightening the tank bolts. Too much force can easily crack the toilet tank or toilet bowl.
  7. Toilet Tank Assembly Replacement: Schritt 7, Bild 1 von 2 Toilet Tank Assembly Replacement: Schritt 7, Bild 2 von 2
    • Lift the tank up from the lower half of the toilet.
    • Set the tank on a thick towel to avoid scraping it against the floor.
Abschluss
11 weitere Nutzer:innen haben diese Anleitung absolviert.
Ron Davis
31.192 Reputation
13 Anleitungen geschrieben
3 Kommentare
Step 5: Clockwise or counter-clockwise depends upon whether you are looking down at the coupling nut from above or up at it from below.
I suspect that, unless it has a left-handed thread, most people would turn it in the direction that works.
John Pretz - Antwort
Close your eyes. Attaching something, the turning motion is (usually) clockwise: Righty-tighty; lefty-loosey.
M J McAllister - Antwort
Thank you for the info.
DonnaRHellman - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 60
Letzte 30 Tage: 204
Insgesamt: 12,773
