Zum Hauptinhalt wechseln
HP Mini 1000 Motherboard Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. HP Mini 1000 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • If present, remove the large piece of black adhesive film covering the area around the fan.
  2. HP Mini 1000 Motherboard Replacement: Schritt 2, Bild 1 von 2 HP Mini 1000 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • If present, remove the pieces of black cloth tape securing the antenna cables to the motherboard.
  3. HP Mini 1000 Motherboard Replacement: Schritt 3, Bild 1 von 2 HP Mini 1000 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Use the flat end of a spudger or your fingers to disconnect the following cables:
    • Speaker cable
    • Microphone cable
    • Fan cable
    • Power cable
    • Display data cable
    • Do not lift the connectors up as you disconnect them from the motherboard. Push the connectors out of their sockets parallel to the face of the logic board toward the display assembly. Use extra care when disconnecting the display data cable, as its connector and socket are fragile.
  4. HP Mini 1000 Motherboard Replacement: Schritt 4, Bild 1 von 2 HP Mini 1000 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Remove the 2.5 mm Phillips screw securing the power switch lever to the lower case.
    • Use a pair of tweezers or your fingers to lift the power switch lever out of the Mini 1000.
  5. HP Mini 1000 Motherboard Replacement: Schritt 5, Bild 1 von 2 HP Mini 1000 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the 2.5 mm Phillips screw securing the wireless on/off switch lever to the lower case.
    • Use tweezers or your fingers to remove the wireless on/off switch lever from the Mini 1000.
  6. HP Mini 1000 Motherboard Replacement: Schritt 6, Bild 1 von 2 HP Mini 1000 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Remove the two 3 mm Phillips screws securing the USB bracket to the lower case.
    • Pry up the USB bracket and remove it from the motherboard.
  7. HP Mini 1000 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the single 4.5 mm Phillips screw securing the motherboard to the lower case near the fan.
  8. HP Mini 1000 Motherboard Replacement: Schritt 8, Bild 1 von 2 HP Mini 1000 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Carefully lift the motherboard from its right edge and remove it from the lower case, minding any cables that may get caught.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 70
