Zum Hauptinhalt wechseln
HP Mini 1000 USB & Power Board Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. HP Mini 1000 USB & Power Board Replacement, USB & Power Board: Schritt 1, Bild 1 von 1
    • If present, remove the two pieces of tape covering the cables routed near the USB and power board.
  2. HP Mini 1000 USB & Power Board Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a pair of tweezers to pull the internal display switch cable straight away from its socket on the USB and power board.
  3. HP Mini 1000 USB & Power Board Replacement: Schritt 3, Bild 1 von 1
    • Peel and de-route the SIM card ribbon cable from its channel on top of the underside of the battery compartment.
    • The SIM card ribbon cable is still connected to the USB and power board. Do not completely remove it yet.
  4. HP Mini 1000 USB & Power Board Replacement: Schritt 4, Bild 1 von 1
    • Remove the single 3 mm Phillips screw that secures the USB and power board as well as the DC jack bracket to the lower case.
  5. HP Mini 1000 USB & Power Board Replacement: Schritt 5, Bild 1 von 2 HP Mini 1000 USB & Power Board Replacement: Schritt 5, Bild 2 von 2
    • Lift the DC jack bracket up off the USB and power board.
  6. HP Mini 1000 USB & Power Board Replacement: Schritt 6, Bild 1 von 2 HP Mini 1000 USB & Power Board Replacement: Schritt 6, Bild 2 von 2
    • Grasp the USB and power board from its left edge, nearest the ports side.
    • Remove the USB and power board straight away from its recess in the lower case, minding any cables that may get tangled.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 39
