Einleitung
If your battery is no longer charging or holding a charge you may need to replace it, in this guide you will learn exactly how to replace the battery in your tablet.
Was du brauchst
There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
4. Remove the tape holding the battery to the plastic frame. The battery is glued to the back of the LED. Pry the battery off the LED using a plastic card.
If replacing the battery, unplug the black and red wires gently from the hardware and take off the battery .
If not replacing it, do not disconnect the red and black wires.
To reassemble your device, follow these instructions in reverse order. Note, you need to solder the battery wires onto the motherboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
