Zum Hauptinhalt wechseln
MacBook Pro 15" Core 2 Duo Model A1211 Bluetooth Antenna Replacement
Was du brauchst
  1. MacBook Pro 15" Core 2 Duo Model A1211 Bluetooth Antenna Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core 2 Duo Model A1211 Bluetooth Antenna Replacement, RAM Shield: Schritt 2, Bild 1 von 1
    • Remove the three identical Phillips screws from the memory door.
  3. MacBook Pro 15" Core 2 Duo Model A1211 Bluetooth Antenna Replacement: Schritt 3, Bild 1 von 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 15" Core 2 Duo Model A1211 Bluetooth Antenna Replacement, Upper Case: Schritt 4, Bild 1 von 1
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
  5. MacBook Pro 15" Core 2 Duo Model A1211 Bluetooth Antenna Replacement: Schritt 5, Bild 1 von 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  6. MacBook Pro 15" Core 2 Duo Model A1211 Bluetooth Antenna Replacement: Schritt 6, Bild 1 von 1
    • Remove the four 3.2 mm Phillips screws on the port side of the computer.
  7. MacBook Pro 15" Core 2 Duo Model A1211 Bluetooth Antenna Replacement: Schritt 7, Bild 1 von 1
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
  8. MacBook Pro 15" Core 2 Duo Model A1211 Bluetooth Antenna Replacement: Schritt 8, Bild 1 von 1
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
  9. MacBook Pro 15" Core 2 Duo Model A1211 Bluetooth Antenna Replacement: Schritt 9, Bild 1 von 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
  10. MacBook Pro 15" Core 2 Duo Model A1211 Bluetooth Antenna Replacement: Schritt 10, Bild 1 von 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
  11. MacBook Pro 15" Core 2 Duo Model A1211 Bluetooth Antenna Replacement, Bluetooth Antenna: Schritt 11, Bild 1 von 1
    • Remove the two Phillips screws securing the black antenna holder to the upper case.
    • Lift the black Bluetooth antenna holder off of the upper case.
  12. MacBook Pro 15" Core 2 Duo Model A1211 Bluetooth Antenna Replacement: Schritt 12, Bild 1 von 1
    • Disconnect the Bluetooth antenna cable from the Bluetooth board.
  13. MacBook Pro 15" Core 2 Duo Model A1211 Bluetooth Antenna Replacement: Schritt 13, Bild 1 von 1
    • Lift the Bluetooth antenna out of its housing in the upper case. The Bluetooth antenna is secured to the upper case with an adhesive, so rocking the antenna board from side to side may help it come free easier.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
iRobot
1 Reputation
636 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 12
Insgesamt: 6,888
