Zum Hauptinhalt wechseln
Palm Treo 755p Circuit Board Replacement
Was du brauchst
  1. Palm Treo 755p Circuit Board Replacement, Battery: Schritt 1, Bild 1 von 3 Palm Treo 755p Circuit Board Replacement, Battery: Schritt 1, Bild 2 von 3 Palm Treo 755p Circuit Board Replacement, Battery: Schritt 1, Bild 3 von 3
    • Press the button on the back cover to release the battery cover.
    • Slide off the battery cover.
  2. Palm Treo 755p Circuit Board Replacement: Schritt 2, Bild 1 von 2 Palm Treo 755p Circuit Board Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery by lifting up on one side.
  3. Palm Treo 755p Circuit Board Replacement, Back Cover: Schritt 3, Bild 1 von 2 Palm Treo 755p Circuit Board Replacement, Back Cover: Schritt 3, Bild 2 von 2
    • Remove the stylus by pulling up on the large top to reveal the top left case screw.
    • Pull away the black flap to reveal the top right case screw.
  4. Palm Treo 755p Circuit Board Replacement: Schritt 4, Bild 1 von 1
    • Use a T5 screwdriver to remove the five 7 mm black/red back case screws.
    • Use a T5 screwdriver to remove the middle 3.1 mm screw.
  5. Palm Treo 755p Circuit Board Replacement: Schritt 5, Bild 1 von 2 Palm Treo 755p Circuit Board Replacement: Schritt 5, Bild 2 von 2
    • Use the plastic opening tool to pry open the device. Start on the volume control side (left side of the screen) and work your way up along the edge and across the top.
    • The side volume control buttons may fall out after opening the device.
  6. Palm Treo 755p Circuit Board Replacement: Schritt 6, Bild 1 von 2 Palm Treo 755p Circuit Board Replacement: Schritt 6, Bild 2 von 2
    • Slowly unfold the back casing away from the front casing revealing the red and black wound wire speaker cable, marked by the red box.
    • Potential for device damage: Be gentle while separating the halves to prevent breaking the red and black wound wire speaker cable that bridges both halves.
  7. Palm Treo 755p Circuit Board Replacement: Schritt 7, Bild 1 von 3 Palm Treo 755p Circuit Board Replacement: Schritt 7, Bild 2 von 3 Palm Treo 755p Circuit Board Replacement: Schritt 7, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves.
  8. Palm Treo 755p Circuit Board Replacement, Circuit Board: Schritt 8, Bild 1 von 1
    Kaufen
    • Gently peel off the protective yellow tape covering the ribbon cable using tweezers or your fingers.
    • ATTENTION: Save the tape for reassembly.
  9. Palm Treo 755p Circuit Board Replacement: Schritt 9, Bild 1 von 2 Palm Treo 755p Circuit Board Replacement: Schritt 9, Bild 2 von 2
    • Using tweezers flip up the black plastic snap covering the small ribbon cable.
    • Using tweezers gently pull out the ribbon cable to detach it from the circuit board.
  10. Palm Treo 755p Circuit Board Replacement: Schritt 10, Bild 1 von 1
    • With the screen facing down. Use the Phillips 00 screwdriver attachment to remove the silver, 0.124 inch long screw on the left side of the circuit board above the ribbon cable.
    • WARNING: Do not over-tighten the screw during reassembly.
  11. Palm Treo 755p Circuit Board Replacement: Schritt 11, Bild 1 von 3 Palm Treo 755p Circuit Board Replacement: Schritt 11, Bild 2 von 3 Palm Treo 755p Circuit Board Replacement: Schritt 11, Bild 3 von 3
    • Pivot the circuit board away from the casing keeping the screen face down.
    • Gently peel away the tape holding the ribbon cable to the screen.
  12. Palm Treo 755p Circuit Board Replacement: Schritt 12, Bild 1 von 2 Palm Treo 755p Circuit Board Replacement: Schritt 12, Bild 2 von 2
    • Using tweezers flip up the black plastic snap covering the ribbon cable attached to the screen.
    • Gently pull out the ribbon cable freeing the circuit board from the casing.
  13. Palm Treo 755p Circuit Board Replacement: Schritt 13, Bild 1 von 2 Palm Treo 755p Circuit Board Replacement: Schritt 13, Bild 2 von 2
    • Separate the circuit board from front cover.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Mike Shaw
601 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 14-6, Forte Winter 2011 Mitglied von Cal Poly, Team 14-6, Forte Winter 2011
CPSU-FORTE-W11S14G6
6 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 1,899
