Zum Hauptinhalt wechseln
Sharp Aquos LC13B2UA Back Case Replacement
Was du brauchst
  1. Sharp Aquos LC13B2UA Back Case Replacement, Stand: Schritt 1, Bild 1 von 2 Sharp Aquos LC13B2UA Back Case Replacement, Stand: Schritt 1, Bild 2 von 2
    • Place the TV face down on a flat smooth surface as to not scratch the screen.
    • Using a Phillips #2 screwdriver remove the four 8mm screws attaching the stand to the TV.
  2. Sharp Aquos LC13B2UA Back Case Replacement: Schritt 2, Bild 1 von 2 Sharp Aquos LC13B2UA Back Case Replacement: Schritt 2, Bild 2 von 2
    • Lift the stand off the television.
  3. Sharp Aquos LC13B2UA Back Case Replacement, Back Case: Schritt 3, Bild 1 von 3 Sharp Aquos LC13B2UA Back Case Replacement, Back Case: Schritt 3, Bild 2 von 3 Sharp Aquos LC13B2UA Back Case Replacement, Back Case: Schritt 3, Bild 3 von 3
    • Remove the two back panels by prying them out with your hands.
  4. Sharp Aquos LC13B2UA Back Case Replacement: Schritt 4, Bild 1 von 2 Sharp Aquos LC13B2UA Back Case Replacement: Schritt 4, Bild 2 von 2
    • Using a Phillips #2 screwdriver, remove the eight 6mm Phillips screws located around the edge.
    • Using a Phillips #2 screwdriver, remove the two 6mm Phillips screws located near the inputs.
  5. Sharp Aquos LC13B2UA Back Case Replacement: Schritt 5, Bild 1 von 1
    • Using your hands, gently lift and remove the back case of the television.
Abschluss
Robert Hobson
1.290 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 1-11, Amido Winter 2011 Mitglied von Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 Mitglieder
Ein Kommentar
How do you remove the casing of a sharp LC26SB25E ? Please.
alan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 4,107
