Einleitung
This guide shows you how to remove the front cover of the phone so that you can access the internal components found there.
Was du brauchst
Apply pressure on the cover while simultaneously sliding the cover downward.
Remove the back battery cover.
Insert the spudger between the base of the phone and the phone battery.
Position the phone so that the battery won't fall out of the phone.
Carefully lift the battery out of the phone.
Find the slight crease on the side that divides the display assembly in half.
Slowly wedge the spudger into the crease.
Run the spudger all along the crease while lifting up.
Separate the front cover from the front base.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
