Zum Hauptinhalt wechseln
Disassembling Nokia 2366i Keypad
Was du brauchst
  1. Disassembling Nokia 2366i Keypad, Battery: Schritt 1, Bild 1 von 2 Disassembling Nokia 2366i Keypad, Battery: Schritt 1, Bild 2 von 2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Keypad: Schritt 2, Bild 1 von 1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Keypad: Schritt 3, Bild 1 von 3 Disassembling Nokia 2366i Keypad: Schritt 3, Bild 2 von 3 Disassembling Nokia 2366i Keypad: Schritt 3, Bild 3 von 3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Keypad, Rear Case: Schritt 4, Bild 1 von 2 Disassembling Nokia 2366i Keypad, Rear Case: Schritt 4, Bild 2 von 2
    • Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
  5. Disassembling Nokia 2366i Keypad: Schritt 5, Bild 1 von 2 Disassembling Nokia 2366i Keypad: Schritt 5, Bild 2 von 2
    • Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver:
    • 2 screws at the bottom
    • 2 screws at the top
  6. Disassembling Nokia 2366i Keypad: Schritt 6, Bild 1 von 2 Disassembling Nokia 2366i Keypad: Schritt 6, Bild 2 von 2
    • Rotate the phone clockwise so the edge is facing you.
    • Insert the spudger in tabs between the outer casing and the inside frame.
    • Slide the spudger upwards.
    • This will remove the rear case of the phone.
  7. Disassembling Nokia 2366i Keypad: Schritt 7, Bild 1 von 1
    • The phone should now be in two different sections.
    • 1) The rear case of the phone.
    • 2) The motherboard and the rest of the phone.
  8. Disassembling Nokia 2366i Keypad, Motherboard: Schritt 8, Bild 1 von 2 Disassembling Nokia 2366i Keypad, Motherboard: Schritt 8, Bild 2 von 2
    • Use the spudger to lift off the yellow clip near the top right corner of the motherboard.
  9. Disassembling Nokia 2366i Keypad: Schritt 9, Bild 1 von 2 Disassembling Nokia 2366i Keypad: Schritt 9, Bild 2 von 2
    • Rotate the phone counterclockwise so that the edge is facing you.
    • Use the spudger to lift the motherboard out of the base of the phone.
    • Remove the motherboard from the base of the phone.
  10. Disassembling Nokia 2366i Keypad, Keypad: Schritt 10, Bild 1 von 1
    • Place key pad in view.
  11. Disassembling Nokia 2366i Keypad: Schritt 11, Bild 1 von 2 Disassembling Nokia 2366i Keypad: Schritt 11, Bild 2 von 2
    • Use your fingers to remove the keypad by carefully pulling from the top of the phone towards the bottom of the phone.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 1-14, Amido Winter 2011 Mitglied von Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
5 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 854
