Einleitung
Removing the side buttons on the phone.
Was du brauchst
Apply pressure on the cover while simultaneously sliding the cover downward.
Remove the back battery cover.
Insert the spudger between the base of the phone and the phone battery.
Position the phone so that the battery won't fall out of the phone.
Carefully lift the battery out of the phone.
Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver:
2 screws at the bottom
2 screws at the top
Insert the spudger in tabs between the outer casing and the inside frame.
Slide the spudger upwards.
The phone should now be in two different sections.
1) The rear case of the phone.
2) The motherboard and the rest of the phone.
Use the spudger to lift off the yellow clip near the top right corner of the motherboard.
Use the spudger to lift the motherboard out of the base of the phone.
Remove the motherboard from the base of the phone.
Use the spudger to pull off the top orange chip attached to the white tab.
Lightly pull up on the white tab to remove the orange tab from the logic board.
