Zum Hauptinhalt wechseln
Disassembling Nokia 2366i Front Display
Was du brauchst
  1. Disassembling Nokia 2366i Front Display, Battery: Schritt 1, Bild 1 von 2 Disassembling Nokia 2366i Front Display, Battery: Schritt 1, Bild 2 von 2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Front Display: Schritt 2, Bild 1 von 1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Front Display: Schritt 3, Bild 1 von 3 Disassembling Nokia 2366i Front Display: Schritt 3, Bild 2 von 3 Disassembling Nokia 2366i Front Display: Schritt 3, Bild 3 von 3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Front Display, Front Cover: Schritt 4, Bild 1 von 1
    • Keep the phone closed.
    • Hold the phones sideways with the front cover of the phone facing up.
  5. Disassembling Nokia 2366i Front Display: Schritt 5, Bild 1 von 2 Disassembling Nokia 2366i Front Display: Schritt 5, Bild 2 von 2
    • Find the slight crease on the side that divides the display assembly in half.
    • Slowly wedge the spudger into the crease.
    • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
  6. Disassembling Nokia 2366i Front Display: Schritt 6, Bild 1 von 2 Disassembling Nokia 2366i Front Display: Schritt 6, Bild 2 von 2
    • Run the spudger all along the crease while lifting up.
    • Separate the front cover from the front base.
  7. Disassembling Nokia 2366i Front Display, Main Display: Schritt 7, Bild 1 von 2 Disassembling Nokia 2366i Front Display, Main Display: Schritt 7, Bild 2 von 2
    • Remove the four 5mm screws on the metal casing using the T6 Torx screwdriver.
  8. Disassembling Nokia 2366i Front Display: Schritt 8, Bild 1 von 2 Disassembling Nokia 2366i Front Display: Schritt 8, Bild 2 von 2
    • Using the spudger, disconnect the green display cable.
  9. Disassembling Nokia 2366i Front Display: Schritt 9, Bild 1 von 3 Disassembling Nokia 2366i Front Display: Schritt 9, Bild 2 von 3 Disassembling Nokia 2366i Front Display: Schritt 9, Bild 3 von 3
    • Lift the metal casing.
    • Be careful not to pull the casing too hard because it is still attached to the phone by a wire.
    • Remove the main display from under the metal casing.
  10. Disassembling Nokia 2366i Front Display, Front Display: Schritt 10, Bild 1 von 3 Disassembling Nokia 2366i Front Display, Front Display: Schritt 10, Bild 2 von 3 Disassembling Nokia 2366i Front Display, Front Display: Schritt 10, Bild 3 von 3
    • Fold the metal casing back over.
    • Disconnect the orange front display data cable with the spudger.
    • Hold the phone so that the antenna is facing towards you.
    • Lift up and flip over the metal casing.
  11. Disassembling Nokia 2366i Front Display: Schritt 11, Bild 1 von 1
    • Using your fingers, remove the front display.
Abschluss
Cal Poly, Team 1-14, Amido Winter 2011 Mitglied von Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
5 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 947
