Einleitung
This guide illustrates how to replace the LCD screen on the Canon PowerShot S400.
Was du brauchst
On the backside of the camera, remove the 4.75 mm screw that sits at the top right corner.
Remove the four 4.75 mm screws that sit at the bottom of the camera.
On the side of the camera, remove the two 4.75 mm screws that sit near the USB digital terminal.
On the side of the camera, remove the four 4.75 mm screws that sit near the wrist strap mount.
Remove the two small metal plates, which the four screws hold in place.
Remove the 3.5 mm screw that sits on the metal plate at the bottom of the camera.
Remove the two other 3.5 mm screws that sit on the side, to the left of the screw you just removed.
A ribbon cable attaches to the metal plate and to the main circuit board, on the front of the camera.
Gently release the black latch.
Remove the ribbon cable and metal plate assembly.
On the backside of the camera, remove the 3.5 mm screw that sits to the left of the viewfinder and above the LCD screen.
Remove the second 3.5 mm screw that sits directly above the LCD screen.
Gently detach the ribbon cable.
Locate the ribbon cable on the main circuit board, which sits below the lens.
Gently release the black latch on the ribbon cable connector and detach the ribbon cable.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
