Zum Hauptinhalt wechseln
Palm TX Front Panel Replacement
Was du brauchst
  1. Palm TX Front Panel Replacement, Back Panel: Schritt 1, Bild 1 von 2 Palm TX Front Panel Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
  2. Palm TX Front Panel Replacement: Schritt 2, Bild 1 von 1
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
  3. Palm TX Front Panel Replacement: Schritt 3, Bild 1 von 2 Palm TX Front Panel Replacement: Schritt 3, Bild 2 von 2
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
  4. Palm TX Front Panel Replacement: Schritt 4, Bild 1 von 2 Palm TX Front Panel Replacement: Schritt 4, Bild 2 von 2
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
  5. Palm TX Front Panel Replacement: Schritt 5, Bild 1 von 2 Palm TX Front Panel Replacement: Schritt 5, Bild 2 von 2
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
  6. Palm TX Front Panel Replacement, Motherboard: Schritt 6, Bild 1 von 2 Palm TX Front Panel Replacement, Motherboard: Schritt 6, Bild 2 von 2
    • Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
  7. Palm TX Front Panel Replacement: Schritt 7, Bild 1 von 2 Palm TX Front Panel Replacement: Schritt 7, Bild 2 von 2
    • Lift the mother board out of the device.
    • A weak adhesive attaches the motherboard to the device.
    • The red wire in the picture will not be attached to your device at this point.
  8. Palm TX Front Panel Replacement, Display: Schritt 8, Bild 1 von 1
    • Orient the device sideways, as shown in the picture.
    • Lightly push the front of the display to separate it from the front panel.
    • The battery in the picture will not be attached to the device at this point.
  9. Palm TX Front Panel Replacement, Buttons and Connector Assembly: Schritt 9, Bild 1 von 1
    • Use a T5 Torx screwdriver to remove the 7.75mm screws at the bottom of the device.
    • It may take some manipulation to remove the screws.
  10. Palm TX Front Panel Replacement: Schritt 10, Bild 1 von 1
    • Lift the button and connector assembly from the front panel.
  11. Palm TX Front Panel Replacement, Front Panel: Schritt 11, Bild 1 von 2 Palm TX Front Panel Replacement, Front Panel: Schritt 11, Bild 2 von 2
    • Lift the rubber buttons off the front panel.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 1-15, Amido Winter 2011 Mitglied von Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 864
