Einleitung
This guide will walk you through the steps to remove and replace the front panel on a Palm T|X.
Was du brauchst
Orient the device so that the display faces forward.
Remove the stylus from the right side.
Turn over the device so that the back panel faces forward.
Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
Rotate the device so that the display faces forward.
Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
Pry along the crevice to loosen the back panel.
Repeat this process for the right side.
Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
Orient the device sideways, as shown in the picture.
Lightly push the front of the display to separate it from the front panel.
Use a T5 Torx screwdriver to remove the 7.75mm screws at the bottom of the device.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
