Zum Hauptinhalt wechseln
Pentax Optio S4i Front and Back Cover Replacement
Was du brauchst
  1. Pentax Optio S4i Front and Back Cover Replacement, Front and Back Cover: Schritt 1, Bild 1 von 2 Pentax Optio S4i Front and Back Cover Replacement, Front and Back Cover: Schritt 1, Bild 2 von 2
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
  2. Pentax Optio S4i Front and Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
  3. Pentax Optio S4i Front and Back Cover Replacement: Schritt 3, Bild 1 von 2 Pentax Optio S4i Front and Back Cover Replacement: Schritt 3, Bild 2 von 2
    • Carefully pull the back of casing away from the front.
  4. Pentax Optio S4i Front and Back Cover Replacement: Schritt 4, Bild 1 von 3 Pentax Optio S4i Front and Back Cover Replacement: Schritt 4, Bild 2 von 3 Pentax Optio S4i Front and Back Cover Replacement: Schritt 4, Bild 3 von 3
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  5. Pentax Optio S4i Front and Back Cover Replacement: Schritt 5, Bild 1 von 2 Pentax Optio S4i Front and Back Cover Replacement: Schritt 5, Bild 2 von 2
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Nicole Wong
329 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 4-29, Regan Winter 2011 Mitglied von Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 3,210
