Was du brauchst
While sliding the silver release tab up, simultaneously lift the cover up from the left side.
Remove the four silver screws using the T5 Torx Screwdriver (T5 x .25 in).
Remove the single black screw that is located beneath the HP sticker with the T5 Torx Screwdriver.
Next, use your plastic removal tool to separate the gray back from the black center piece.
For better results, start the separation at the corner piece.
Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
Next, remove the wire from the bottom of the mother board.
Make sure all the connections are properly disconnected before separation from the motherboard.
Next, use a plastic removal tool and separate the silver front case from the black frame.
Now that the front cover is removed we will need to disconnect the LCD screen from the mother board. Pull the LCD connection out of the slot to properly disconnect.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Next we will need to remove the last wire from the motherboard
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
