Einleitung
This guide demonstrates how to replace the housing of a Canon Powershot A610. In order to get to the internals of the Canon A610, the plastic casing around the camera must be removed.
Was du brauchst
Unlock the battery cover, while swinging the cover outward to open it.
Turn the camera over and allow the batteries to fall out.
Close the battery cover.
Remove the three 3 mm screws that attach the side panel to the body of the camera.
Using your fingernails, pull the side panel outward to remove it.
Remove the two remaining 2 mm screws that attach to the frame of the camera.
Remove the 3 mm screw that sits at the bottom of the camera, near the front side.
Remove the 4 mm screw that sits at the bottom of the camera, near the back side.
Open the battery cover.
Remove the 5 mm screw that sits on the top of the battery slot.
Remove the three 6 mm screws that sit at the bottom of the battery slot.
Open the digital A/V DC terminal cover.
Remove the three 4 mm screws.
Detach the digital A/V DC terminal.
Grip the sides of the top cover and gently lift it until it detaches from the camera.
With the camera upside down, pull the side of the front case that is closest to you, in an outward movement.
Open the memory card slot cover.
Remove the 3 mm screw that sits near the bottom of the case.
Flip the LCD screen all the way open.
Grip both sides of top of the back case and gently pull it, in an outward movement, until the case detaches.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
