Einleitung
This guide goes through the procedure of replacing the lens in the Sony Cybershot DSC-P52.
Was du brauchst
Open the battery compartment and remove the batteries.
Remove all of the visible screws on the outside of the case.
Open the memory card compartment.
Remove the screw next to the memory card slot.
Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
Detach the ribbon cables and unplug the cable leading to the back of the motherboard.
Remove the screw indicated in the picture to detach the lens and the viewfinder from the other hardware.
Purchase a new viewfinder.
Repeat the previous steps in reverse order to rebuild.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
