Einleitung
Use this guide to replace the LCD. The LCD tends to fade after about five years.
Was du brauchst
Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
Pry up the panel; starting from the front/bottom corner, as indicated.
There's a concealed lip, under the opposite edge.
Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
Use the Spudger on the edges of the screen.
Once one end is lose, use the tweezers to lift the screen.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
