Korg Toneworks AX1500G Pedal Switch Replacement
  1. Korg Toneworks AX1500G Pedal Switch Replacement, Pedal Switch: step 1, image 1 of 1
    • Remove the black 8.0mm Phillips screws from the back of the Pedal Board.
    • Be careful when working with small electronics, as many of the components are fragile.
  2. Korg Toneworks AX1500G Pedal Switch Replacement: step 2, image 1 of 3 Korg Toneworks AX1500G Pedal Switch Replacement: step 2, image 2 of 3 Korg Toneworks AX1500G Pedal Switch Replacement: step 2, image 3 of 3
    • Remove the back panel of the board.
  3. Korg Toneworks AX1500G Pedal Switch Replacement: step 3, image 1 of 1
    • Unscrew the five golden 8.0mm Phillips screws holding down the left circuit board.
    • Be careful not to hit to metal parts on the circuit board, this could cause sparks and failure.
  4. Korg Toneworks AX1500G Pedal Switch Replacement: step 4, image 1 of 3 Korg Toneworks AX1500G Pedal Switch Replacement: step 4, image 2 of 3 Korg Toneworks AX1500G Pedal Switch Replacement: step 4, image 3 of 3
    • Carefully unplug three wires connecting the left circuit board to the right circuit board.
    • The wires may be stuck and difficult to remove. Try to pull from the plastic part.
  5. Korg Toneworks AX1500G Pedal Switch Replacement: step 5, image 1 of 3 Korg Toneworks AX1500G Pedal Switch Replacement: step 5, image 2 of 3 Korg Toneworks AX1500G Pedal Switch Replacement: step 5, image 3 of 3
    • The circuit board is still connected at this point.
    • Carefully pull out the circuit board and turn it over.
    • Unplug the last cable connecting it to the other large circuit board.
  6. Korg Toneworks AX1500G Pedal Switch Replacement: step 6, image 1 of 1
    • Unscrew the two 8.0 mm black Phillips screws from the small circuit board.
  7. Korg Toneworks AX1500G Pedal Switch Replacement: step 7, image 1 of 3 Korg Toneworks AX1500G Pedal Switch Replacement: step 7, image 2 of 3 Korg Toneworks AX1500G Pedal Switch Replacement: step 7, image 3 of 3
    • Gently pull out the small circuit board by the purple wire.
  8. Korg Toneworks AX1500G Pedal Switch Replacement: step 8, image 1 of 3 Korg Toneworks AX1500G Pedal Switch Replacement: step 8, image 2 of 3 Korg Toneworks AX1500G Pedal Switch Replacement: step 8, image 3 of 3
    • Mark the wire connected to the small circuit board so for future reference.
  9. Korg Toneworks AX1500G Pedal Switch Replacement: step 9, image 1 of 3 Korg Toneworks AX1500G Pedal Switch Replacement: step 9, image 2 of 3 Korg Toneworks AX1500G Pedal Switch Replacement: step 9, image 3 of 3
    • Soldering Irons can be very dangerous if you are inexperienced.
    • Desolder the wires connecting to the board and remove the board.
    • Solder the new foot switch circuit on
3 other people completed this guide.
Gabriel Maraboto
200 Reputation
1 Guide authored
Cal Poly, Team 14-6, Green Fall 2015 Member of Cal Poly, Team 14-6, Green Fall 2015
CPSU-GREEN-F15S14G6
5 Members
6 Guides authored
3 Comments
Thanks! My Ax1500g's pedal switch volume is failing, and not reaching the 100% volume, not even 50%. I've opened the pedalboard and removed the pedal switch, but I notice It doesn't have any true connection to the switchboard but an LED with a PhotoSensor that may be blocked by a plastic in the pedal itself, is that how it works? I was expecting a Potenciometer.
Where can I buy the pedal switch board replacement?
309001200 PHOTO TR RPM-22PB N OR P KLM-2251 AX150 1
312051900 PHOTO SENSOR SIM-22ST Q OR R KLM-2251 AX150 1
Thanks
Martin Jofre - Reply
Bro
Thers is some noise comeing when i connect the cable
I give to one shop
3 times. I took the shop he is cheater i lost my money
I need to fix it bro
I need ur help
Samuel Arun - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 23
All Time: 4,835
