Zum Hauptinhalt wechseln
2013 Subaru Impreza WRX Mud Flaps Replacement
Was du brauchst
  1. 2013 Subaru Impreza WRX Mud Flaps Replacement, Mud Flaps: Schritt 1, Bild 1 von 1
    • Always make sure your car is off, the parking break is applied, and you are in a safe area free from other passing cars.
  2. 2013 Subaru Impreza WRX Mud Flaps Replacement: Schritt 2, Bild 1 von 1
    • Turn the wheels all the way towards the side you will be working on.
    • This will create easier access to the inside of the wheel well when you are replacing the mud flap.
  3. 2013 Subaru Impreza WRX Mud Flaps Replacement: Schritt 3, Bild 1 von 3 2013 Subaru Impreza WRX Mud Flaps Replacement: Schritt 3, Bild 2 von 3 2013 Subaru Impreza WRX Mud Flaps Replacement: Schritt 3, Bild 3 von 3
    • Start with the front mud flaps.
    • Attach the 7/16th size socket piece to the wrench and begin removing the 7/16th diameter nuts.
  4. 2013 Subaru Impreza WRX Mud Flaps Replacement: Schritt 4, Bild 1 von 3 2013 Subaru Impreza WRX Mud Flaps Replacement: Schritt 4, Bild 2 von 3 2013 Subaru Impreza WRX Mud Flaps Replacement: Schritt 4, Bild 3 von 3
    • Use your Philips Head screwdriver to unscrew the farthest #6 3/4" Stainless Philips Screw.
    • Be careful not to loose the rubber gasket attached to the screw.
  5. 2013 Subaru Impreza WRX Mud Flaps Replacement: Schritt 5, Bild 1 von 3 2013 Subaru Impreza WRX Mud Flaps Replacement: Schritt 5, Bild 2 von 3 2013 Subaru Impreza WRX Mud Flaps Replacement: Schritt 5, Bild 3 von 3
    • Once the old mud flap is removed, grab your new mud flap and reattach it in the same manner as how you removed the old or broken one.
    • Repeat for opposite front mud flap.
  6. 2013 Subaru Impreza WRX Mud Flaps Replacement: Schritt 6, Bild 1 von 3 2013 Subaru Impreza WRX Mud Flaps Replacement: Schritt 6, Bild 2 von 3 2013 Subaru Impreza WRX Mud Flaps Replacement: Schritt 6, Bild 3 von 3
    • For the back two mud flaps you will need to use a slightly different technique due to the limited space you will be working in.
    • Use your hands and the 10mm wrench piece to unbolt the mud flap.
    • Once you have removed the nuts, you can move on to the #6 3/4" Philips Head Screw.
    • This step will be aided by the use of an extra small Philips screwdriver.
  7. 2013 Subaru Impreza WRX Mud Flaps Replacement: Schritt 7, Bild 1 von 2 2013 Subaru Impreza WRX Mud Flaps Replacement: Schritt 7, Bild 2 von 2
    • Replace both back mud flaps and fasten all pieces back in place.
  8. 2013 Subaru Impreza WRX Mud Flaps Replacement: Schritt 8, Bild 1 von 2 2013 Subaru Impreza WRX Mud Flaps Replacement: Schritt 8, Bild 2 von 2
    • Make sure the mud flaps are all properly tightened and positioned before driving your car again.
    • Enjoy your brand new mud flaps.
Abschluss
Alex Davis
101 Reputation
1 Anleitung geschrieben
Cal Poly, Team 14-3, Green Fall 2015 Mitglied von Cal Poly, Team 14-3, Green Fall 2015
CPSU-GREEN-F15S14G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 24
Insgesamt: 942
