Einleitung
Are your mud flaps cracked or broken? Use this guide to replace your mud flaps to look brand new.
Was du brauchst
Start with the front mud flaps.
Attach the 7/16th size socket piece to the wrench and begin removing the 7/16th diameter nuts.
Use your Philips Head screwdriver to unscrew the farthest #6 3/4" Stainless Philips Screw.
Be careful not to loose the rubber gasket attached to the screw.
Once the old mud flap is removed, grab your new mud flap and reattach it in the same manner as how you removed the old or broken one.
Repeat for opposite front mud flap.
Use your hands and the 10mm wrench piece to unbolt the mud flap.
Once you have removed the nuts, you can move on to the #6 3/4" Philips Head Screw.
