Zum Hauptinhalt wechseln
Replacing a Casio Exilim EX-Z850 Speaker
Was du brauchst
  1. Replacing a Casio Exilim EX-Z850 Speaker, Speaker: Schritt 1, Bild 1 von 3 Replacing a Casio Exilim EX-Z850 Speaker, Speaker: Schritt 1, Bild 2 von 3 Replacing a Casio Exilim EX-Z850 Speaker, Speaker: Schritt 1, Bild 3 von 3
    • Remove the screws on both sides and the bottom of the camera with the Phillips #00 screwdriver.
    • The bottom screws are longer than the side screw.
  2. Replacing a Casio Exilim EX-Z850 Speaker: Schritt 2, Bild 1 von 1
    • Gently pry apart the rear casing from the body of the camera.
    • Do not pull the casing completely away from the camera or you will damage the ribbon securing the rear casing to the contents inside the camera.
  3. Replacing a Casio Exilim EX-Z850 Speaker: Schritt 3, Bild 1 von 2 Replacing a Casio Exilim EX-Z850 Speaker: Schritt 3, Bild 2 von 2
    • Use the tweezers to gently peel the ribbon from the contents inside of the camera, leaving it connected to the rear casing.
    • Set aside rear casing.
  4. Replacing a Casio Exilim EX-Z850 Speaker: Schritt 4, Bild 1 von 2 Replacing a Casio Exilim EX-Z850 Speaker: Schritt 4, Bild 2 von 2
    • Use the tweezers to pry the LCD screen from the frame.
    • The bottom of the LCD screen is attached to the frame by black tape.
  5. Replacing a Casio Exilim EX-Z850 Speaker: Schritt 5, Bild 1 von 2 Replacing a Casio Exilim EX-Z850 Speaker: Schritt 5, Bild 2 von 2
    • Use the tweezers to flip the LCD screen to the other side.
    • The LCD screen has a ribbon on the bottom of it that is connected to the contents inside of the camera, do not pull it apart.
  6. Replacing a Casio Exilim EX-Z850 Speaker: Schritt 6, Bild 1 von 2 Replacing a Casio Exilim EX-Z850 Speaker: Schritt 6, Bild 2 von 2
    • Pry the LCD casing from the tape that is underneath it and then flip it to the opposite side to expose the contents under it.
  7. Replacing a Casio Exilim EX-Z850 Speaker: Schritt 7, Bild 1 von 3 Replacing a Casio Exilim EX-Z850 Speaker: Schritt 7, Bild 2 von 3 Replacing a Casio Exilim EX-Z850 Speaker: Schritt 7, Bild 3 von 3
    • Use the tweezers to flip open the connector that is holding the ribbon connected to the LCD screen in place.
    • Remove the LCD screen with the ribbon from the camera.
  8. Replacing a Casio Exilim EX-Z850 Speaker: Schritt 8, Bild 1 von 2 Replacing a Casio Exilim EX-Z850 Speaker: Schritt 8, Bild 2 von 2
    • Remove the front casing from the body of the camera.
  9. Replacing a Casio Exilim EX-Z850 Speaker: Schritt 9, Bild 1 von 2 Replacing a Casio Exilim EX-Z850 Speaker: Schritt 9, Bild 2 von 2
    • Remove two screws on the side where the battery is located using the Phillips #00 screwdriver.
    • Pull the side casing so it becomes dislocated from the top of the camera frame.
  10. Replacing a Casio Exilim EX-Z850 Speaker: Schritt 10, Bild 1 von 2 Replacing a Casio Exilim EX-Z850 Speaker: Schritt 10, Bild 2 von 2
    • On the front of the camera, near the flash flip, there is a connector holding a ribbon. Remove the ribbon from the connector.
  11. Replacing a Casio Exilim EX-Z850 Speaker: Schritt 11, Bild 1 von 3 Replacing a Casio Exilim EX-Z850 Speaker: Schritt 11, Bild 2 von 3 Replacing a Casio Exilim EX-Z850 Speaker: Schritt 11, Bild 3 von 3
    • Carefully remove the L shaped frame from the camera by popping the frame off the bumps and tabs located at the bottom of the camera.
    • There is a yellow and orange wire soldered onto the camera. Be careful not to disconnect them.
    • The blue box is the speaker.
  12. Replacing a Casio Exilim EX-Z850 Speaker: Schritt 12, Bild 1 von 1
    • Use the tweezers to remove the speaker.
Abschluss
Christian
320 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 4-38, Regan Winter 2011 Mitglied von Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 13
Insgesamt: 2,677
